Turning on lights or interior heater causes idle to drop.
vancouverbc
Car: 1991 240sx
What is supposed to raise idle in this situation? aac? ficd? ?
xekushnr
Car: '90 Nissan 240SX Hatch
sounds normal to me. how much does the idle drop? what do you idle at with nothing on?
vancouverbc
Car: 1991 240sx
drops 50 with lights and 100 with interior heater. it idles around 700 with nothing on.
if i leave a vacuum hose open , the idle only increases 50 rpm.
doainwpg
try raising your idle a little, if you've got a 5spd you should be idling between 750-800rpm.
rico05
Car: 1992 RMS13 w/ CA18DET
Weclome to classic Japanese car wiring. Get a better grounding setup and that should clear right up.
