Turning off Engine w/o Turning off ACC
SnowSurfLax
Car: 1999.5 Infiniti QX4
2006 Infiniti M35 Sport
Is there a way to turn off the engine but leave the accessories on? I find it irritating when in the middle of a call and I've parked and have to wait for it to come back up to continue. Or to have to turn it back on to have the radio.
I tried searching, but didn't find much.
AD1787
Car: 2007 M45 Sport Twilight Blue
I think we are out of luck there. I use my cell phone menu to "switch to cellphone" so that the bluetootn is dropped and then turn off the car. The caller never knows that you've switched from car bluetooth back to the phone
M4T5
Car: 2007 Infiniti M45
SnowSurfLax wrote:Is there a way to turn off the engine but leave the accessories on? I find it irritating when in the middle of a call and I've parked and have to wait for it to come back up to continue. Or to have to turn it back on to have the radio.
I would have to say no. Two things I could think of for you to try: 1.Don't turn off your car until your ready to get out of it.
2.Try placing it into neutral and then press the start/ off button. It may shut the engine off, but not all of the ACC until you place it into Park.Good Luck!
J
ghstudio
The last post is correct. Turn the engine off without putting the car in park and the engine will stop but the car will remain in acc.
The to turn the car off completely, put the car in park, keep your foot off the brake, push the on/off button and the car will go on, but the engine won't start...then push again and the car will go off.
ArbitrageMan
Car: 2006 M45 Sport
ghstudio wrote:The last post is correct. Turn the engine off without putting the car in park and the engine will stop but the car will remain in acc.
Indeed. And if you shift into Park, the ACC will stay on. If you want to restart the car, press the brake and press the button.
SnowSurfLax
Ugh. Seems annoying. Maybe we need to send Infiniti some requests to put some sort of option in for that, say maybe holding the button down?
I wouldn't change how it works, just slip in an option to leave the accessories on without having to turn everything off and then back on.
AD1787
You know what you need...
MORE COWBELL
SnowSurfLax
Thanks! That was helpful
marlin29311
Car: 2008 Infiniti G35x
...actually, with the push button start, you can just put the car in park and tap the button twice quickly. I do this all the time when I am on the phone and have reached my destination. Just turn the car off normally, but hit the push button a second time really quickly, and ACC will come on with no gap in power.
M4T5
Great tip, but I still think the Neutral then off, then to park is just as easy.
J
lawman12
marlin29311 wrote:...actually, with the push button start, you can just put the car in park and tap the button twice quickly. I do this all the time when I am on the phone and have reached my destination. Just turn the car off normally, but hit the push button a second time really quickly, and ACC will come on with no gap in power.
I usually do this.
