http://www.controlgenie.com/vdckit/cf516 wrote:looks like it did the trick. thanks. is there anyway to keep it permanently off?
ha, how deep was your foot into the go-button when that happened?cliffz wrote:I WAS DRIVING MINE IN THE MIDDLE OF SUMMER WHEN I HIT A LITTLE PUDDLE OF WATER FROM SOME SPRINKLERS ON THE SIDE OF THE ROAD AND INSTANTLY WENT INTO AN IRRECOVERABLE SPINOUT. DID A 360 AND STRAIGHT INTO A TREE. LUCKY TO BE ALIVE.
Hey there Wall of Text, it looks like your ears got damaged too - turn off the Caps Lock.cliffz wrote:LET ME WARN EVERYONE ABOU THE DANGER OF TURNING OFF THE VDC. IT IS A VERY DIFFERENT CAR WITH IT OFF AND YOU PROBABLY DON'T REALIZE HOW OFTEN IT SAVES YOUR a** FROM SPINNING OUT. I TOTALLED MY FIRST 350 BECAUSE I WAS DRIVING WITH IT OFF. YOU NEED TO TURN IT OFF ONLY WHEN YOU PLAN ON DRIFTING OR DOING DONUTS. ALMOST 300HP TO THE REAR WHEELS IS MORE THAN ANY TIRES YOU CAN FIT ON THE Z CAN HANDLE IN A TURN AND YOUR BACK END WILL KICK OUT ON YOU CONSTANTLY. THAT IS NO FUN WHEN YOU ARE NOT EXPECTING IT. KEEP IT ON NORMALLY. KEEP IT ON IN THE RAIN. KEEP IT ON UNLESS YOU HAVE A LOT OF ROOM AROUND YOU TO RECOVER FROM WHAT WILL HAPPEN WHEN YOU HIT THE GAS IN A TURN OR HIT A PUDDLE WHILE ACCELLERATING. I WAS DRIVING MINE IN THE MIDDLE OF SUMMER WHEN I HIT A LITTLE PUDDLE OF WATER FROM SOME SPRINKLERS ON THE SIDE OF THE ROAD AND INSTANTLY WENT INTO AN IRRECOVERABLE SPINOUT. DID A 360 AND STRAIGHT INTO A TREE. LUCKY TO BE ALIVE.
