Sil240 »
https://forums.nicoclub.com/sil240-u6842.html
Thu Oct 16, 2008 10:02 am
Do you still have your boost solenoid hooked up??Because the ecu shouldn't have any idea of how much boost your running other than the larger amount of airflow.
Its possible that you've run out of injectors and the computer has recognized this and hit fuel cut. (Totally Guessing, have no idea)
I was thinking maybe you maxed out the MAF, but you said yo uhave a Z32 maf and a SAFC.The safc lets you use the Z32 maf correct?
Does the SAFC tell you your injector duty cycle?You shouldn't be more than 80%If your 80 and over you'll over heat the injectors.
