turn the damn lights off
Amature240
Car: Cars, Computers
Ok well... if anyone read my little story on my road trip adventure they will know that my car is a PEICE OF ****. But anyway.. one of the things the cop gave us a warning for (while he was laughing his *** off ) was non working brake , turn signals. ect in the back so.. today i was pokeing around between classes and i realized that they we just disconnected.. so i was like damn this is going to be easy connected the bastards and now........ they wont go off.. just on all the time.... ITs like a fat kid at an all you can eat buffet you just cant get them to go away.. If you got any ideas please let me know
SpeedRacer1
Car: 1990 240SX, G35
Check the fuses and also check to see that the bulbs that are in the sockets are the proper ones. Example: having a single filiment bulb where a dual filiment bulb should can cause lights to never turn off and blow fuses.
dlop240
That's your brakelight switch it's right on the pedal most likely if you get underneath your dash feel for where the switch is, the pedal should have like a plastic piece that makes contact with the switch turning your lights off most likely it broke and you'll feel a hole there on the brake pedal and the switch going through it. To fix that just get a small bolt and nut to cover the hole and make contact with the switch. Hope that helps.
