Turn signals stop working
Twin Ts
Car: 93 Nissan 300zx TT
Changed all bulbs, checked the flasher combo. Is there a different flasher from the hazards? My hazards work. Help..
centralcoaster33
Car: 1997 Nissan 240SX #5
Mine had separate flashers for blinker and hazzard, but I didn't have a 93 300zx. You can check your service manual to be sure or just hunt longer. I did have my turn signals go haywire for a while. It was some gum up in the contacts for the selector stalk. I had to pull off the column plastic covers, unscrew the signal stalk, wipe the contact surface with a paper towel soaked in rubbing alcohol, the put it back together and all was working fine.
Welcome to NICO Club!
Twin Ts
Thank you. I will clean the contacts and see what happens.
Glad to be a part of greatness....
boostin300
Car: 1991 300zxTT ------ Current project
2011 Jetta SEL ------ Daily
1985 Toyota pickup - Sold
1986 RX-7--------- Sold
2001 Golf 1.8t------ Sold
any luck with the signals? im having the same issue
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
More often than not it's the issue Dave described with the signal stalk being the issue.
boostin300
Took off the signal stalk and it checks out. But it seems from the shop manual that power goes through the hazard switch first. Then to the stalk. So I jumpered 1 and 3 and now the stalk works as it should. So seems like I need a new hazard switch module.
boostin300
Here's a video of the issues i was having and what i did to fix it. hope it can help someone
https://youtu.be/DDU5EKJhlwk
