At first I was guessing the bulbs, but if it's the whole enchilada, could it be a wiring issue?Kiven422 wrote:94Q - My turn signals work on and off. When you flip the signal theres no signal and the hazards won't work either. Then the next time I need to use them, they work like normal.
Would like to pinpoint the issue asap. Motorcycle cops are the worst in my town... They don't seem to care about speeding as much as they do when it comes to a clear acrylic cover on your rear license plate. Got a fix-it for that one.
I haven't seen you mention the fuse. It's the Hazard Lamps fuse in the engine compartment fuse box (4th from the bottom?).Kiven422 wrote:Bulbs are fine. The signals work just like they should when they wanna work.
If you decide you need a hazard switch don't buy one. I've got a couple and since we only live 25 miles apart....gammer_ghn wrote:well i had the same problem on my lincoln continental... the problem came from the hazard switch.....and i had a short inside the car. so your best bet is to go to your stealership.......
haha i traded that piece of **** in for my Q lol ill never buy a Fix Or Repair Daily product again in my life.goody94q45 wrote:
