Fibre guy »
https://forums.nicoclub.com/fibre-guy-u128603.html
Sat May 30, 2009 4:03 pm
The actual click you hear when turning the wheel around is from a thin metal disc with slots in it behind the steering wheel for the s13's. Could be the disc bent or the little plastic piece in the turn signal arm broke. Its an easy fix to just replace the entire turn signal arm and disc with a junkyard one. I had the same problem. Just replaced it with the metal disc from my r33 front clip.
