turn signals don't work :(
vitaminZ
Car: 1990 Nissan 300ZX
My turn signals won't work..its not the bulbs..my 4 way comes on..but my actual left right turn signal doesn't work :confused:
any ideas..all the fuses seem to be good.
xclusivez32
Car: 1990 300zx 2 seater limo
tt engine build
2004 gmc serria
it might be the switch is bad because the 4 ways are on a different switch
vitaminZ
But when I flick the hi beam it works on the same lever
vitaminZ
i just ordered the assembly 70 bucks used :)
xclusivez32
tt engine build
2004 gmc serria
the signals are on the colum not where the headlight switch is
vitaminZ
I know that.. But the flicker to turn your high beam on to flash people is on the same lever.. Its called a combination switch
Nismo513
Car: 1990 300zx twin turbo
-hks blow off valves
-intercooler and turbo piping
-3" exhaust and downpipes
-Apexi super afc controller
-20lbs boost
-18" ADR racing wheels
Hey vitamin I know this a old post but im having same issue and was wondering if you got it solved when you ordered new one?
vitaminZ
it was the relay
