Turn signals and keyfob?
jmercjr
Car: 1999 Nissan Pathfinder
OK, So heres my sob story. My 10 month old pitbull decides my keyfob would make the pefect chew toy. The next day I open my car door (1999 Pathfinder)and the alarm goes off. Im trying to use the keyfob to reset it but its obviously broken. Finally I get it to reset and so I snap the keybob apart (pieces fly everywhere) so it dont go off again. After this my turn signals quit working. Checked the fuse, its good! I order a new keybob and program it. I think it is programmed but it will not lock/unlock doors but makes a clicking sound under the dash as if a relay is making and breaking. Any suggestions? Any correlation to the turn signals? Thanks
4xq
Well it's late and just about bed time, but my quick reaction would be to set the alarm off with the key fob and then go thru the standard procedure to turn the alarm off using the key fob and see if that resets everything.
Sounds like you didn't do the standard turn off procedure. Can't remember what it is right at the moment tho.
