Mjkkb2 »
https://forums.nicoclub.com/mjkkb2-u226599.html
Wed Jun 11, 2014 6:15 pm
Looks like your signal bulb is out. My bet would be on the socket being the culprit, possibly overheating. The problem is figuring out which one it is - front or back as I believe both will flash fast if one malfunctions. I think I'd try removing the rear since it appears easier to do (never done it on the M so don't hold me to it) and inspect. If the bulb is out but no other signs of smoked housing, melted base/ socket etc, then the bulb just gave out. If no signs, including perfectly looking bulb, then the front is the most likely problem. Just repeat the whole thing.
