turn signal
A home for 1983–1989 300ZX owners!
nuinqua
Car: 1972 Datsun 240z
The turn signal on my '72 240 seems to only wanna work when it wants. The blinker is slow and sometimes I can hear the relay but the turn signals won't light up. Sometimes it just won't do anything. Has anyone had this problem before? Where is the relay? Behind the dash? or might I need a new turn signal switch? Thanks.
hitbychance
Car: 2008 350z
2008 Dodge Ram 1500 4x4 5.7L hemi
i have a 82 280zx and my relay "flasher" is above the gas and brake peddles it looks like a silver cannister
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
I believe the relay si in the same area but on the older Z's the switch is an issue, they actually switch the hot side which causes a current drop and they tend to wear out after 30-40 years might want to try locatiiong a good used switch stalk
nuinqua
Ok, thanks ...i'mma have to try and find a used one, cuz new are like two hundred buck.
Pharaohabq
Car: 92' Nissan 300ZX NA
look on Ebay, muchas cheaper!
hitbychance
Car: 2008 350z
if you are buying a new one try talking the one u have out now and cleaning the contacts with some small grit sand paper worked for me for a while before the relay went, but the switch is still goin
Pharaohabq
you can also use a good pencil eraser. it cleans contacts pretty well and is less harsh than even fine sandpaper. Phar
nuinqua
Yeah, I took it apart and cleaned the contacts and replaced the tiny little spring that holds a ball bearing and it works good now. The most difficult part was finding a spring, luckily a friend had a box full of springs that he said he brought from Harbor Frieght. Thanks.
Return to “300ZX (Z31) Forum”
