turn signal & side marker lights
General discussion forum about all things Datsun! NOTE: If your thread is specific to a certain model, please make sure you post it in the proper forum.
datsunexcells
Cleaning up your turn signal and side marker lights can really make a difference in the way they look. I used a rotary-type electric toothbrush to clean the inside of the lens, and Novus 2 plastic polish on the outside. I used Westley's BLECHE-WITE, whitewall cleaner, with a toothbrush and fine wire brass brush to get through the years of crud on the rubber light bases. I treated all the rubber parts with ArmorAll after they were clean. Iused polishing compound to clean the metal trim for the lights. The lights look like new. John
71-521
sounds great!
Post up some pics!
Return to “Datsun Chat”
