turn signal removal 98 maxima(easy way)?
elballoonrat
Car: turbo mr2
ive got a 98 maxima that the turn signal needs to be replaced, the low one down in the bumper. i tried getting to it but the wheel well cover among other things is in the way. any easy way to pop it out? or do i just need to buckle down and spend an after noon removing all the plastic coverings and such. all it needs is a new bulb im thinkin. thanks everyone
maxhopper
Car: 02 Maxima SE 6spd
Take a flat-head screw driver, place it between the two lenses and carefully pry out the lens that's on the side (or rear). It may be a lttle difficult, but it will come right out. After that lens is removed, if you need to remove the other (front) lens, you will see a screw. Just remove that screw and the lens will come out.
