Post by chuy38 » https://forums.nicoclub.com/chuy38-u57507.html Fri May 18, 2007 5:28 am
Post by DrewQ45 » https://forums.nicoclub.com/drewq45-u2328.html Fri May 18, 2007 5:52 am
You may have a loose/dirty connection. I'd say pull the cluster, clean the contacts and apply dieletric grease to the contacts and plugs. (I used an old toothbrush and brake cleaner)... I've learned that it's very important to use dielectric grease on all plugs/sockets. Makes life a lot easier when pulling them, prevents degradation of the connection from corrosion and the plugs snap into place firmly with minimal effort... somethign important when big ham hands such as mine and trying to manuever behind the cluster.chuy38 wrote:My turn signal lights are not flashing on dash and speedometer cuts in and out with power steering going along with it. Do I need a whole new cluster and where can I get one.
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
