Eriko »
https://forums.nicoclub.com/eriko-u186327.html
Wed Dec 21, 2011 12:48 am
Im not sure on the 10s and 11s, hell, im not even sure if the bulbs will work for me since I have an 08... Yup, you will need resistors otherwise they will hyperblink. You can check by looking at the bulb socket. If thiers 3 leading wires,1 for ground and the other 2 for the blinker and corner marker. Then it will be plug n play and all you will need is the led bulb. If the socket is 2 pins then im not sure. If they will work. I will be messing with mine since its only a 2 pin socket and try to get the led light to work. Sorry if this doesnt make since, its midnight were im at.
