current6 »
https://forums.nicoclub.com/current6-u180929.html
Tue Mar 15, 2011 8:37 pm
Hello all, new to this site. I have a 1980 Datsun 720 I picked up for $500 and am working on restoring. I put a new weber carb on and i cant figure out where the vac line from the distributor advance is supposed to go on it. any help there would be appreciated, I have the truck running smooth other than idle problems when engine is cold. That line should fix that. Also I just put in some brand new turn signals I ordered, there were none there when i got it. I also got the new light switch assembly, since it was broken. I got all of the lights working except the backup lights are not coming on, and the turn signals are not working at all. Like I said, brand new lights and switch, checked all the fuses in the block in front of drivers door, and replaced the flashers. Also pulled apart the hazard light switch and cleaned out all the corrosion. Any Ideas on what to check next would be very helpful. As soon as I have time I will take some pics and post a thread of all the work I have done so far. Unfortunately I didn't take "before pics, but I will do my best to describe what It was like in the post.
