Hi. I have been a proud owner of 1969 SRL2000 for the past 18 years. Its been an extremely reliable car ever since I got it. Even when my garage got flooded up to my knees after a bad storm several years ago, the car did not give me any problems.
I noticed the other day that both of my turns signals stopped working. I also noticed that the rear left brake lights no longer work (right side works). I’m hoping someone can help me with this….
When I turn the headlights on, all of the tail lamps (as well as the front amber lights) turn on dim as they should. Also when I turn the hazards on, all of the tail lamps flash as they should. (Hazards always flashed extremely slowly, so no change there). Brake lights work for the right side only as I mentioned.
I did take a look at the silver relay cans underneath the dash. I interchanged them but no effect. (hazards work using either silver can). I noticed that when I turn the hazards on, there is power to blue (+), and green wire (-). But there seems to be no power on the other two wires that goes to the other can– white (I presume +), and green (I presume (-)), even when I turn the turn signal switch left or right.
Can anyone help me out with this? I took out the steering wheel as well but the switch area in the steering column looked complex and I was not sure how to get the switch out. I need to get the car inspected for spring but without the turn signals it won’t pass inspection in NY…
