turn off dashboard warning lights
Nissan 350z / Nissan 370z technical discussion forum: Maintenance, performance, installations, modifications, how-to's and troubleshooting.
Hayseed
Car: 2007 Nissan 350Z
Can someone direct me to the postings that may cover, the issue with turning off dashboard lights. My tire went low, I aired it up, and checked all the others and brought them all to within the guidelines. Now the light is still there warning me. Another light staying lit is the airbag light. I bought the car with an aftermarket wheel installed, and was told that was why the airbag light was lit. I changed it out and put the stock wheel back on with the airbag in place, and the light is still on. I don’t have any literature that came with the car. It’s a 2007 350. Thanks for any and all help.
Reason: Revise Title
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Airbag lights won't go away until they're cleared with a scanner, even when the cause of the failed SRT has been repaired. They won't go out by themselves after a successful SRT like a lit engine lamp.
Vis the TPMS light, most of them won't go out until you drive a few miles after airing up. If you've done that and it's still lit, chances are the lamp is from a bad sensor in one of the wheels and not from low air. On most Nissan systems the lamp will flash for awhile after startup if there's a problem other than a low tire.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Hayseed
Thanks for the information, I have a 60 dollar scanner, not sure it will do the job, and thanks for the link.
Return to “350z / 370z Technical”
