TurboXS H34 BOV
SCOOBYSHAG
Anyone here with any experience with it? Couldnt find anything on the search function
Nathan
I have one, but not installed...Slw240sx has one too...he thinks it leaks a bit. I've heard good stuff about them though (hence I bought one).
UsedToOwn240SX
Car: Radio Control Racing, Counterstrike
I have one, installed & run on my redtop. I like it. The fact that it's recirculating means that you don't have the rich problem during shifting. It's still kind of noisy when you shift though. I wish it were a lot quieter. I installed it at the stock location (inside fender just below where the air box used to be).
SCOOBYSHAG
did it come with a flange?
Nathan
umm...kinda...there is a short aluminum tube you could have welded to your IC piping that it screws on too...but it's not quite a flange.
UsedToOwn240SX
Yup, no flange. The H-34 includes an tube extension. This extension is connected to the racing bypass by 2 set screws. It fits good and has o-ring to help seal the connection. I just buy a radiator hose of the same diameter and connect it to the pipe from my Greddy FMIC. I'm pretty satisfied with the H-34 at the moment. I haven't turn up the boost yet however. I'm sure it should hold up high boost. I think it's rated up to 25 psi.
hokiruu
Car: 2012 INFINITI M37X Platinum Graphite
'95 240sx/s14 SR20DET (in 2000) SOLD
so you are still able to hear a pretty lound discharge sound when it recirculates?
UsedToOwn240SX
Yup, woooosssshhh. Still pretty loud. I think ppl will know it's turbocharged when they hear it whoosh-ing like that.
SRdave240
I have one too. It is much louder than I thought if would be since it is recirculated.
How may spacers (washers)are you guys using with stock boost, I think mine is leaking under acceleration.
UsedToOwn240SX
I put none. How do you know if it's leaking, srdave240? Do you get about 7 psi? I have autometer boost gauge, and it says about 7 psi full boost (stock). I can't compare it with the stock bypass valve, since this is my first turbocharged car. I have full boost at around a little over 3000 RPM with big-28.
SRdave240
I could feel it leak when revving it in neutral so i put one spacer in it. It doesn't seem to leak anymore except I think I hear it when I am driving. My boost gauge isn't installed yet so I'm not sure,
