C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Mon May 04, 2009 12:32 pm
Welcome to NICO.
First off, please attempt proper grammar. While you don't need to write us an "A" paper, lack of any proper grammar makes your posts difficult to read. Considering your issue is likely quite technical in nature, it helps immensely in assisting you to diagnose a problem when we can clearly understand what you mean to say.
Now, as far as your issue, the first step would be to figure out what the smoke is comprised of. To make sure I understand you correctly, the problem is occuring only when shifting from second to third and when boosting in 6th? This obviously presents a problem in trying to figure out what the smoke is made of as you can't smell it while sitting in idle. You may need help from a friend, perhaps one who is familiar with certain smells from cars. But basically, your friend needs to smell the smoke after your car emits it to determine what it is. It's likely to be coolant or oil. Coolant pretty much smells like coolant and will have a humid feel to the smell. Oil is quite a bit more noxious. I have a hard time describing it, but it is quite distinct and recognizable if you've smelled it before. Determining the type of smoke you are dealing with helps to narrow down your focus to the oil system or the cooling system. Both oil and coolant can produce a very white smoke.
Also, make sure you are not mistaking a light greyish particulate looking smoke with white. Many turbo equipped vehicles will produce a spot of greyish smoke under load (sometimes longer depending on how rich the tune is), or the transition to high loads. And given that the Turbonetics kit deletes the catalytic converter, it may be much easier to see the effects of a rich condition.
That said, I have some questions. How long have you had the kit on the car? How long has it been smoking? Do you have a turbo timer installed? Can you visibly see the smoke while driving or did someone else point it out to you?
Its quite possible its an oil related problem, but if it is and it is occurring at the turbo, then you need to determine the specific cause as well. Oil seal failures in a turbo can and do occur, but if you have too much oil pressure at the turbo (turbos need very little oil pressure), the drain is clogged or kinked, it can easily cause oil to leak passed the seals. This is a problem for every turbo regardless of who makes it. If there is an actual bearing failure, you can check for shaft play. But outside of oil starvation, oil coking in the bearings or severe turbo surge, it would be unlikely that a ball bearing turbo would experience a bearing failure.
As for swapping to another Turbo brand for a replacement 60-1, outside of sourcing one from Garrett, there aren't going to be much better options as Turbonetics turbos are generally pretty good. And even if you do go to Garrett, you might run into some fitment issues as Turbonetics turbine housing dimensions can differ slightly. Particularly in the offset from the center of the turbine exit to the turbine inlet. This could cause problems with fitting the turbo to the existing plumbing. Double check this one though as it has been a long time since I checked the specs and can't recall if the issue is limited to a specific turbine housing configuration or not.
