well said..Darkness and Light wrote:If you get a correct ECU tune you shouldn't need to tune it with the SAFC or mess around with a different fuel pressure regulator. You also don't need to adjust your base timing because the ECU tune will retard the timing.
I don't think most of the gauges are really necessary as long as the tune is correct and the cooling system, etc. is running properly to begin with. They will give you clues if things start to go wrong, but you would have to be paying proper attention and be able to understand them. I doubt anyone could be expected to watch 6 gauges, speedometer, tach, gas level, three mirrors and the road all at the same time. Besides you would need to get a wideband O2 sensor to go with the AFR gauge if you wanted to use it for tuning.
For the amount of money you are shelling out and questions you're asking I'm thinking you would be better off asking a local shop to do the install and tune a standalone ECU for you. You get local service and someone else you can blame (and sue) if the engine blows. Some standalones or addons to the standalones can track all that information for diagnostics or show digital gauges on a screen if you really want that information. With some of the more upscale boost controllers, you don't need a boost gauge because the controller can display boost.
WDRacing wrote:This isn't the SR forum...GET OUT...lol.
WD
