turboing a KA questions.
240sxkadet
Im am going to turbo my KA bc it makes more sence than to get the SR IMO. bigger engine , build it for turbo = more hp. but i was wondering, what all needs to be done b4 adding a turbo. i have 125,000 miles. i know im ganna need the turbo setup with teh manifold and all but i mean internally what would be suggested, and what is the best turbo to run on the KA.and shuld i change the compresion withthe pistons.and what else should be done. thanks , joe
240marcuSX
Car: E34 525i
E46 M3
do a compression test to make sure everything is ok. Correct me if im wrong (i have an S13) but your car has 9:1 compression which is ok for turbo, but you can get like 8.5:1 pistons, and/or thicker head gasket. if you have the extra money, you could rebuild it from the bottom up, depending on how much boost you want to run.
Basically just make sure your motor is running fine without turbo, before you add turbo, make sense?
my $0.02
240sxkadet
yea that is what the compresion on the >95's. i just had a compresion test and everything is ok, but ill soon need a new distributor rotor that is the only thing that is bad on my car, bc i had a service at nissan. would u recomend getting a kit or peicing everything together. and im trying to save as much money as possible bc of college.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Need more details - You looking for all out power?
You want 250rwhp???
How much is your budget?
And ALL of the KA24DEs in the S13 and S14 have 9.5:1 static compression...which will be fine if you tune it right.
Later - Brian
240sxkadet
i want power. as much as possible. i want to have around 300hp at about 10psi. i think with a kit i can et that. but kits are pretty expensive though. but i dont want to have to piece everything together. and is there a kit that comes with EVERYTHING inc. FMIC.
240sxkadet
i was thinking about getting the XS engineering turbo kit. has anyone heard ne thing good ro bad about that kit.
trpower7
SEARCH more. You are asking very basic questions that we've covered a thousand times.
240marcuSX
Car: E34 525i
E46 M3
sorry, i wasnt for sure on the compression of the DE since i dont own one. If you really want to save money you can go the junkyard route volvo intercooler, 300zx T3, muffler shop IC piping, etc...
the IAP kit is a very complete kit it has everything youd need minus some fuel stuff like ECU or SAFC, injectors, pump. but no matter what you do, youre gonna spend a few Gs unless you go junkyard.
I may end up buying a kit, or just buying some parts from places that sell kits, and getting other parts cheaper elsewhere.
TurboKA37
300 rwhp? if thats ur goal ur looking at jwt ecu retune, stand alone, or hacked MAF because the stock MAF will max out around 240-250. thats my biggest consern when people post on here for the first time and want to make major power of kits and a SAFC
240sxkadet
i think im going to go with a kit, but which one is the best, i was looking at the XS, the nsport, the new greddy and the IAP kit, but i noticed the fuel system was better on the greddy, and i can get a FMIC for pretty cheap. but for the money which is the best kit.
Silent Drifter
Car: '93 Nissan hatch
'90 Nissan coupe
'96 Ford Ranger
Looking for a bike!
If you want that much hp I would suggest getting forged pistons an some good rings. Youll definatly need a different maf personally im goin with a z32 an Safc 2, others are usin cobra maf an jwt ecu. Its up to you an how much money your willing to put out.
