turboing a 89 240sx
paintballpro69
Car: '95 Nissan 240SX
alright i got the turbo, the guages, the fmic, the bov, everything basicly but the piping wont work and the manifold.. if i am to turbo the stock engined 89 240sx what will i need to pull this off jsut the manifold and piping? where shoul di go about getting this and how much u think?
mrflip69
Go in the KA-T forum. It's under the 240sx section...
(On that note, I must say I miss the old layout/organization of the old forums... especially with all the hybrids running around)
paintballpro69
alright thanks i was told mine wasnt a ka or is it a ka and just a sohc version instead of the early 90's dohc?
supra brit
Car: '93 Supra, '94 240sx 'vert
89-90 = sohc
You left out injectors/fuel system upgrades...you plan on doing anything with those?
edit: And make sure you don't get boost happy...especially on a KA's stock internals...better? (Ya'll get so offensive!)
I've heard 12 psi is a good limit...
Modified by one80sxy at 5:26 PM 10/18/2004
Altiman94
Car: 1989 Nissan 240SX
e=stronger than de. NIce try.
paintballpro69
the fuel system and injectors are probably stock.. wht u suggest i should get? what psi should i run at also on that engine?
again liek what would i need to turbo it jsut piping and manifold? or would i need a new ecu or something or how do i let my ecu know that i havea turbo?
Chingon
Car: 1991 and 1992 hatchbacks
^^pshh...that's nonesense, you can get plenty happy w/a ka24et.
http://www.turbo240sx.ca/http://ka-t.or ... ns...2.htm
supra brit
Altiman94 wrote:e=stronger than de. NIce try.
Is it really? Why?
paintballpro69
im already happy with my car. i jsut want a lil more umpf. so if i can turbo it then why not.. i got the **** but do i jsut need manifold and piping?
auxiliary
one80sxy wrote:
Is it really? Why?
Well for one thing, the Compression is a little lower, so that is always going to help with turboing a car. And I believe the head is designed a little different.
The Mic
Car: 3Z Wmb
brit, every side has their cult.
Now i dont wanna sound like a jerk, this is just fyi that you may or may not know. But if you don't have the big front mount paintballpro69 your going to have to stay down on the boost a bit (no more than about 10psi or your asking for trouble). Also a side note, the stock fuel pump isn't going to support over 8psi (if your lucky) so please don't try it or your going to end up with melted pistons. Upgrade to the Z32TT, Skyline, or Walbro as one of your first mods. For 1 bar of boost it is required that you upgrade the fuel pump to a 190/255Lph Walbro or a 300Z TT Fuel Pump. The 300Z Fuel Filter also is a very good and cheap mod. Keep in mind you dont absolutely need a 255Lph fuel pump ... it supports 490 hp. You can save 20 bucks and get a 190Lph fuel pump that supports 425 hp. Oh and as for the clutch, the stocker wont handle the upped boost very well. Its advised you upgrade to a good aftermarket upgraded clutch.
Info on DEs and E http://www.nicoclub.com/zerothread?id=38554
[Zero-S]
Car: Tell me whats wrong with this picture. 3 240's, only one runs.
240SX KA is a 240SX KA. One cam vs two. Oh noes.
I prefer the DE because its what I have experience in.
paintballpro69
so get a new fuel pump, filter, and clutch? i got a big front mount too itll be fine. any electronics i will need? anyone know where to get piping? anyone know where to get the manifold for a turbo ka? thanks
[Zero-S]
Anywhere but ssautochrome.
paintballpro69
whats wrong with them? any suggested sites for the manifold?
Altiman94
the e has all iron block, same forged rods, and a lower compression ratio than that of the de.
The Mic
Car: 3Z Wmb
a boost gauge is essential from now on. This is to ensure you are running the correct boost. Other gauges include EGT, Water Temp, Oil Temp/Pressure, etc. Those are nice to have but arent 100% necessary until you upgrade the turbo. Before the boost wasnt really enough to justify a turbo timer because a simple 20-40 seconds of idling before you turn off the car would suffice. Now that you are pushing the turbine to its effective limit you will need to always remember to let it cool to avoid oil coking and bearing damage. The easiest way to do this is to have a turbo timer installed. It allows the car to run with the key out of the ignition for a set time.
check with http://www.brmexhaust.com/ for manifold
paintballpro69
thanks. i was lookin at some hks and greddy turbo timers too. now im just pricing all thisout and seeing if its worth doing turboing and rebuilding the stock engine or doing the swap. well see. thanks a lot man
paintballpro69
alright i think i got all the info i need. i put it all on my cardomain page so i can remember. now to price **** out and find it all:) thanks again guys
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
240sx.org has a few write-ups on turboin KA's might wanna check that out
paintballpro69
thanks man ill go check that out. i wanna findm soemone else who did what im doing to get there ideas. nice car too bro^
mynismo
[Zero-S wrote:]Anywhere but ssautochrome.
they make good quality tubular manifolds now. the one i have on my car is from them (off ebay).
its good quality... i bought from them before, and for $99 i won't hesitate to do it again.
paintballpro69
99 bucks.. im there! haha thanks
l3ooherS14
Car: 1995 Nissan 240sx S14
paintballpro69 wrote:so get a new fuel pump, filter, and clutch? i got a big front mount too itll be fine. any electronics i will need? anyone know where to get piping? anyone know where to get the manifold for a turbo ka? thanks
I agree. The DOHC just seems better in any way possible. KA Power....
paintballpro69
umm hows does my quote have anythign to do with tht? ok though... well the thing is im broke.. i need to make my car fast as possible on a budget and a swap isnt an option.. can i just get a ka24de upper end on my current engine? prob not j/w
drifter_for_life06
Car: Daily: '16 WRX
Exocet
i wonder the same
did you check out 240sx.org
paintballpro69
no not yet i just took a nap.. haha dude ur car is sick. im headin over to 240sx.org right now
drifter_for_life06
Car: Daily: '16 WRX
Exocet
lemme know if 240sx.org helps
paintballpro69
ya i just got off that site that site rocks. full install from a tuenrs perspective with words i understood and step by step ****.. awesom einformation mostly on my sohc ka too... even told me some other upgrades i wasnt thinking about. as far as if a ka24de upper end works on a ka24e i did not find that out it would be a nice thing to knwo though. anyone else know? thanks
drifter_for_life06
Car: Daily: '16 WRX
Exocet
glad you found some helpful info
i believe the heads can we swapped
