Guishnu wrote:So is that 530hp at the wheels? Of a totally stock block?That's insane. Sorry to be bugging you for questions but:What turbo are you running to spool @ 3000rpm??What type of exhaust system are you running?Are you running that 530hp on av gas?
If yours does 530hp in that trim. I can't even imagine what mine is going to do with twin turbo's, pistons, inlet and exhaust manifolds, head gaskets and a built head.
It should be bloody amazing.
I can't tell you all how excited i am
I have custom exhuast manifolds that even though they are a log type would flow a **** load more than stock.The turbo is a Garret T04z with 1.14ar (I think but might be 1.15ar) so isn't really a small turbo. ie good for 850hp.The exhuast is 3"untill the muffler about 4"away. The waste gate pipe which is 2" joins just bfore the muffler.The muffler is a very small 3" straight through resonator (Coby type) with 4" pipe running from there and exits in front of the left side rear wheel. Youcould say it is fairly loud!!!!!!!!! But it is certifid, registered and has a current WOF so 100% road legal in NZ! But all over the WOF sheet they wrote 'competition vehicle'.It is tuned to run on avgas only. I ran short last week and had to put some 95 to get home, so I put 10l of 95 and a full 500ml bottle of octane booster in and it ran OK but I did drive it like a nana.
I have no imediate plans for bigger injectors as I have so much usable power now that until I learn to drive with this I have no need for more.
I think I've repeated myself a few time in this thread so sorry for that, I'm just trying to explain the results.
