saf »
https://forums.nicoclub.com/saf-u121121.html
Fri Nov 28, 2008 2:42 pm
Interesting Q, and while i could go into a lot of detail on the cycle of function of a turbo 4, say the CA, you really cant at the same time. A pistol, will work in a specified function as you say, and its a one way street.
However in a engine, data is not only being read, its being analysed and altered, then sent back to other parts. While a MAF or AFM (not the same) can read a volume of air, and its density at the ecu, the ecu then sends a signal to the injector on its next opening, "so this, for this long". However, if Mr knock sensor chimes in, the cycle of function for that one command is now altered, and it needs to send new signals, to ign and fuel systems.
As fara s some of the other q's, yes a bov at the TB region is best. The reason a BOV is used, is for safety, not perf, and what happens is the TB closes with say 120,000rpm of shaft speed at your compressor, and you get a shockwave off the TB plate, back down the system. This is enough to blow apart IC lines, and even backspin the turbo (because the EGF - ex gas flow, has fallen to almost nothing aswell) at times snapping thinner shafts.
If you place the BOV at the TB (near to) it lets go of pressure at the point of the shockwake origin. We talk about a few extra psi, but in volume, its a lot. The difference between 8 and 12 psi is 4psi on paper, and not much in the realworld ... but in a motor, thats 4 pounds extra per square inch. Now measure the displacement from the tip of the comp blade, piping, FMIC, plenum, runners, head and to piston top .... its a lot more volume.
And this is the sole reason for upping boost, not pressure, volume. Pressure doesnt make a engine go hard, its the volume of air because your compressing it, hence the pressure. A T25 at 18psi can perhaps flow 270hp for eg in a engine. In that same engine a HKS T51R SPL at 15psi can say flow 680hp.
Exhaust notes, well loose a muffler and you will get turbo whistle. It wont sound like a N/A civic (thank god) but it will be loud. The larger your turbo (exhaust side), the more engine noise.
WTA IC's are superb when designed well, and setup right. My Celica GT4 is on its OEM WTA, and it pushed out around 320hp at the flywheel, with a better system its capable of more, however so is the weight factor, and potential for items to fail.
EGT probes are cool, but in all honesty you need one in every cylinder, in the runner at a 45deg angle with the tip in the sentre of the exhaust port facing the exhaust valve. AT that point only will you see a inconsistancy in each cyl to see if head hot spotting or intake runner distribution is a problem. And even then when we have run up big turbos, the engines come online so hard and fast, a K-type (common) still doesnt react fast enough. having a EGT probe in a common collector is common, and all its good for is to get a baseline temp, and if something goes slightly off, you see a spike (if your lucky) in EGT's. In order i rate gauges as boost, then fuel pressure, oil temp, egt and water temp.
Hope that answered a couple of q's.
