speedeast »
https://forums.nicoclub.com/speedeast-u139789.html
Wed Dec 01, 2010 8:41 am
On a 4-cyl car, turbochargers are definitely more successful. Most people use a supercharger when they only want to throw in a few pounds of boost - nothing too impressive. Turbochargers are considered "free power" bolt-ons because the engine does no extra work to create boost. It uses the engines normal cycle to create boost; it's very creative. Superchargers, on the other hand, add another pulley that the engine has to turn in order to simply idle.
You're going to hear stories about turbo lag, but that only really occurs when your setup isn't optimal.
When someone only adds a few pounds with a supercharger, it's usually because they don't want to invest in replacing the components necessary to run a turbocharger. They are certainly capable of creating more boost, but then you have to replace the same components and now you have the power-robbing of the two options. Consider wisely. You can do a search of the site and read on some of the hundreds of other threads comparing the two.
