Turbo XS RFL BOV
taylzyadigg
Car: 08 CBR 600RR, AE86, S13
All fellow CA! I have a Turbo XS RFL BOV from my WRX that I no longer use and was wondering if anyone has ever ran this bov on the ca18det. If some one has run or is running this bov please help me, diagrams, pics, explanations,etc. Thanks. Opinions Welcomed!
float_6969
get a weld on flange, weld it on the pipe, hook up the vac line, and adjust.
It's no different than any other BOV.
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
rfl is... well... REALLY f***ING LOUD!
taylzyadigg
I have the adapter kit for the wrx...that 2 bolt oval shape. What kind of flange would I need to weld on there? I already have a hot pipe, but with no flange. Also I have searched and the dispute over where to mount the BOV still troubles me.
float_6969
As close to the throttle body as possible. You should be able to buy a weld on adapter for that BOV.
taylzyadigg
So looking at the motor....it should be placed on the left side of the motor...the TB side correct. Thanks for your help, Im looking for a flange right now. You think a muffler shop can just weld one on? Then they would have to cut the hot pipe. Sorry, NOOB in the house.
zero_gripS13
Car: soon to be 95 s14 hopefully
if ur cold pipe is aluminum make sure to point that out to them lol... not all welders can weld aluminum (people and machine)
taylzyadigg
Ebay has this polished hot pipe I guess that says "Adapter pipe XS" Im guessing the Turbo XS replica bov they have. Think I am better off going with that. They have a 2.5 in. and a 3 in. pipe. I hope it will work with the bov that I have.
taylzyadigg
I know there is a dispute with running an open bov or a recir. bov. but for my application do you guys think its a good idea (turbo xs) to be mounted?Im concerned about the motor and the turbo especially. Some say they run open with out standalone and it runs fine besides alittle rich, other say its the worse thing you can do. Help please! If its absolutely bad then ill sell it. If its good enough I'll mount it since its one that I already own. Thanks.
