Turbo XS H-RFL BOV question
I ask good questions
Car: 92 240 SXSE Coupe with SR20DET
What are the washers for that come with the BOV?
Nismo_180sx
Car: 1990 Nissan 240sx SE Redtop SR20DET with bolt-ons
I believe you stack them up inside the BOV, the more washers the less travel of the piston and vise versa. So I guess more washers=quieter BOV or it will take more air pressure for it to blow-off. Either way the XS H-RFl is just more of a noise maker than anything. I believe anything more than 19 psi and it starts to leak. (heard about this on twinturbo.net, when I had my TT Z.) I'd just go with the HKS SSQ or GReddy BOV, better product and more functional than just a noise maker.
I hope I didnt offend anyone that owns an XS-RFL
- Jeremy
I bought one the other day off of a guy for 100 brand new in box. I was just never sure of the washers. Ive only got a t-28 so ill never be running high boost. And in all actuallity i bought it for the sound lol. I just want people to know that im boosted!
ILikeMy240sx
Car: SR Power
I pumped up my intercooler system with about 40 lbs of air and never did my RFL leak once...
DRIFTINIZ
where do u guys mount your RFL's.....is it custom, or will it mount to lets say a greddy or hks hotpipe w/a pre-welded flange??
DawgMode
Car: 180sx
lol u guys..hahahaha
tha washers purpose is just like tha purpose of tha screws on tha greddy and hks...they tighten tha seal for higher boost levelsu put them on tha bottom of tha brass piston to put most tension on tha spring...so if it leaks just unscrew tha top(becareful of spring)and drop one or two of em at a time until it seals......Nismo_180sx....i have a lot of friends who run this BOV its a great bov for the price u cant beat it..not to mention RFL -REAL-****IN-LOUD
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
ive never had a problem with the rfl, or the h34. it has held to many 30+ psi pressure tests, and lots of boosting. i mounted mine on the provide sleeve, but worried about it leaking there, so i just used a small section of hose to connect it.
ILikeMy240sx
Car: SR Power
I just bought an alum tube that fits inside the BOV, and cut it then took it to somewhere that did Alum welding. No leaks so far.
srpowered240sx
mine didnt leak either, i was just worried; it was more for peace of mind.
