rico05 »
https://forums.nicoclub.com/rico05-u8176.html
Tue Mar 31, 2009 1:17 pm
That is just general coolant line routing.
For the feed, it is a line that goes from under the intake mani to the back of the intake manifold to the turbo. There are several hard lines with hard vac lines in an assembly that bolts to the back of the head. Since I am not in a cold climate and I do not run the butterfly system (what the vac line is for), I removed the assembly, cut the line on the turbo side, and run a steel braided line in place. Much cleaner.
