Turbo Usage on rb20
LeD ippen
Car: 1993 Nissan 240sx SE
So i have this Gt35 with a ar .68 exhaust and .70 compressor laying around. i am wondering if it would suit the rb20 or is it to awkward. i would need to get supporting mods for it such as injectors. just wondering if its okay to use it. has a a vband exhaust housing so it be easy to fab although its 4" >.>
current mods
pod
3" turbo back
Fmic
nismo fpr
nistune
walboro
n1 pump
collar
acl bearings
current turbo is gt2510 >.> responsive but lacking.....
LeD ippen
It is also a t4 flange so i would need to get adapter plate with the stock mani or get a new one.
just wondering if its okay to use on rb20 not sure of flow charts for it.
RustspecS13
Car: '74 260z and '88 300zx turbo
It wont make good power till around 4500-5000 range and up. Not very responsive compared to your GT25. Unless your looking for 500+Whp then I doubt you'll like it.
A GT28 or GT30R is probably more your style. The GT35R is a 600whp turbo, while the GT30R is capable of about 500WHP maxed out, and a GT28R is capable of about 400whp depending on the type. These are the absolute max power figures at the wheels, most will run them 100-150whp less then that.
How much power are you trying to make?
~Alex
LeD ippen
I just had it laying around so i though about using it. i dont care about the respon as much but if it revs from 4.5-8k then that good enough for me. looking to make 4-450 hp sooner or later. you think if i change the exhaust i get better response?
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
you will need injectors/Z32 good tune not sure if u will need cams.
