Turbo upgrade
speedfreak358
Car: 1993 240 sx
I want to upgrade the turbo on my redtop for my s13.
What kind of turbo do u guys suggest?
Also how much boost should i run.....safely, haha i dont want anything to go ka-boom.
Thanks
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
Try searching for some help. The turbo you need depends upon your ultimate goals and/or needs. On a stock bottom end (crank, pistons, etc.), Enjuku racing put out 540 whp on an SR. The stock Headgasket is only good to about 15 psi IIRC. Searching will yield a plethora of info for you to digest. If you are asking this kind of question though, I suggest you do tons of research, then come ask questions on the forums, then do more research, to make wise decisions about what you want/need.
speedfreak358
Car: 1993 240 sx
ok ill def do my research then, im new to the whole turbo thing this is my first car with a turbo, so id figure id ask around and c what ppl had to say. thanks.
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
Figure out what you will be using your car for and pick a Horse power number based on your cash flow. I think the Magic number would be 400WHP That would be a close horse-power to waight ratio of a Ferrari F430 BUT you must be able to handle a car with that much power!If you just came from a 80 Fwhp honda civic, Learn how to handle the RWD beast that is the Nissan 240sx with the stock sr20det first!Always upgrade the Tires , suspension , breaks and steering before power upgrades!
Kalypso
Garrett gt2871rz32 MAF550cc fuel injectorsHKS 264/264 cams JWT ecu
400 hp
supreamS14
550cc injectors will be @ 95% duty cycle (not good) with 400 flywheel HP! Thats about 365 whp. You can take them to 400whp MAX on c16 race gas but even that is pushing it past 95 % duty cycle I would not take 550cc past 330-350whp on pump gas myself.
Kalypso
hes right 770cc injectors instead
speedfreak358
Car: 1993 240 sx
ok awesome thats for the input guys, i'll def get used to the stock sr first, and no im not coming from a honda civic haha, this is my first car, iv had it with the ka for a little over a year now, but im looking for more haha.
Thanks!
S14toRPS13
The cheapest common one is the S15 turbo. Which can put you up to about 300 whp, with supporting mods ofcourse. The GT2871R is also a very popular one like mentioned above. If I didn't already have my GT2530, that's the turbo I'd get. Have a horsepower goal and then choose the right size turbo.
Kalypso
S14toRPS13 wrote: Have a horsepower goal and then choose the right size turbo.
well said, this is a common question on the thread but my suggestion is more fundemental.
when I took my s13 to the track with a stock t25 and some tein coil overs, the car opened up and felt so damn fast. After that experience i didnt crave a bigger turbo, what I wanted was more track time.
once you've fully appreciated you're cars true potential, you'll have definite knowledge of how to improve your car and how you want it to drive.
