turbo upgrade
mxd
Car: music
i need some help on where to send my t25 for a upgrade to a t28 or whatever could put me in the 300-350hpthanks
lessthanjakejohn
Your going to want to replace your entire turbo.
At what RPM do you want peak horsepower?
mxd
Car: music
3500rpm would be nice what do you think!
jmillheiser
that would be nice for peak torque too low for peak HP.
sylvia spec SR20DETs all have peak HP at 6000 and peak torque at 4000 in stock config (even the S15s).
on an upgraded turbo expect both those RPM figures to climb especially in the 300+hp range. of cousre the SR can handle it to a point
mxd
Car: music
ok thats good but what i need is a store on the web that cant do it and for how much,i was thimking of s15 t28 but now im thinking of upgrading!
bp2ooo
http://www.cheapturbo.com
Cheap turbo prices. :)
SRdS14
Car: Workin on my car, chillin with friends, basically whatever...
haha...BP took my line!!! f u c k e r!!! ;)
BuudWeizErr
http://www.forcedperformance.n...8.htm
I'm thinking about that. Even though it's for DSM's, they do it for SR20's too.
bp2ooo
sorry srd. Beat you to it...
bp2ooo
bud do you know if its the same price for the sr20 t25? That looks like a really good deal, and no one would expect 20 pounds of boost, from what appears to be a t25. Would make the car run 12's for sure. :)
hokiruu
Car: 2012 INFINITI M37X Platinum Graphite
'95 240sx/s14 SR20DET (in 2000) SOLD
Heavy Throttle sells DSpeed turbo kits with turbo and manifold for $1800. Not sure what size turbo it is but its rated at 325hp and its bb. Sounds like what you want. Probably good beause its the only turbo upgrade HT sells and DSpeed is good stuff (they only make parts for Silvias). Give them a call and ask about the turbo. That way you can tell me. If you get it, I can decide whether I want it or not.
bp2ooo
that sounds like a good deal, but it would be really nice to have a bottom mounted turbo that is capable of 20 psi and looks like a stock t25. No one would think it would be as quick as it is with such a small turbo and no bottle. Sr swap is my prject this winter. Next winter i will do turbo and fuel stuff i am hoping.
hokiruu
bp2000: That's the thing, the Dspeed kit IS bolt up to factory position. The manifold is only for better flow. What you are describing for top mount is the Enjuku t3/04 kit exactly. It is $2800. BTW I am on the exact plan as you, June is SR swap. Next Spring maybe turbo upgrade.
bp2ooo
wow that kits sounds really nice. I wonder how all the welds are on the manifold. Anyways i wish heavy throttle updated there site more, and had more info and prices on sr stuff. If you end up getting it, or have pictures or anything let me know.
wow, thats funny, right after i posted that i check out heavy throttle's website and its updated. First time in like a year i think. O well there still cool as hell.
BuudWeizErr
bp, I email'd them and they said it was the same price for the SR20 T25, and that "they do them all the time."
bp2ooo
Sounds cool. I will have to email them when i get a little more money saved up.
mike_do
is it only the turbo??? doesn't come w/ anything else and bolts right onto the sr20 manifold?? and can handle 21 psi man sounds like deal :) how much hp do u think it's good for?? oh and i' talking bout the forced performance turbo
bp2ooo
it appears that you would send them the turbo. They would use the stock t25 hosuing, but build it to a monster bb t28 in t25 housing. everything would bolt up, and on the car they are using it on they are running 21 psi. It makes full boost at a little over 3000 rpms. sounds like a hell of a deal. I think im going to do that, injectors, and do something for a fuel controller next winter, and ill be 12's for sure.
Heavy throttle did a dyno on a t25/t3 hybrid they did. Pretty much upgraded stock t25, and at 20 psi it put down 300 hp, and 320 torque, On 93 octane. They are pretty sure the car will be mid-low 12's. here is the linkhttp://www.srswap.com/html/gal...s.htm
Dori Dori
Car: Cars of course
That Heavy Throttle car is poo. The fact that they used a 1.8mm metal head gasket at those power levels makes me go->:confused:
I H8 UR DSM
a t25/t3 is not the same as the FP Big28....
Jesserpi
hokiruu
Yeah, their site was real weak for awhile. So we still don't know what kind of turbo is on that Dspeed kit? I will try to find out.
