Turbo Upgrade Questions
idamaster
Car: 92' 240sx, 98' 328i
Im looking for a really cheap upgrade from stock t25. Looking to run about 20-22psi.
1. Is this a good enough kit? If not list the reason(s).http://www.cxracing.com/mm5/me...=TOKT
2. On top of a headgasket what else would I need? Ive already got a FMIC/BOV.
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
1. I dunno, every company has to start somewhere. I'd buy their radiators, but I'd want to know who made that turbo and hope the manifold doesn't crack in a few weeks.
2. Aside, from HG and BOV/IC? You still need a healthy motor, larger fuel injectors, fuel pump, ROM-tune/standalone/cheater piggy-back, boost controller, better engine cooling, heat shielding for the BMC, a few other little things....I think I'm missing something else
idamaster
homeslicej2 wrote:1. I dunno, every company has to start somewhere. I'd buy their radiators, but I'd want to know who made that turbo and hope the manifold doesn't crack in a few weeks.
Motors got about 40k miles, stock injectors, walbro pump, koyo radiator, rocker arm stoppers, and ACT street clutch.
grenade180sx
Car: 180sx
i have the Cx kit... the turbo is fine for me so far. dyno'd at 335 at 14psi on a stock SR with SAFC and 460cc injectors.
im upgrading to 550cc and tuning on Race gas to see what she can do at 18-20 psi.
the exhaust mani sucks tho. buy a cast one if u can!
MrSoutherland
Car: S13 - Sr20
Did someone tell you that the motor has about 40k miles? Or did you have it rebuilt and have put 40k on it?If some one told you that, get a leak down test and a compression test. If your numbers there are fine then go for the kit. However if the numbers are bad then your motor wont last very long at all with that kit.
idamaster
I think what im going to do is go for 15psi.Apex HGApr studsthat turbo kit850cc Injectors
Ive already got:Fmic, Rocker arm stoppers, walbro pump, koyo radiator, rocker arm stoppers, and ACT street clutch as far as motor transmission goes.
Anything else I should add to the list?
kentuckyslider
Car: 02 IS300 manual/03 G35 sedan auto
get a rom tune and a Z32 maf or cobra maf. + all the parts you mentioned above.
I would get a GT2871R if it was me. Spool quicker, higher quality with oem mani, less heat soak, just as much or more power and less cheap parts to break.
idamaster
Siemens Deka 850cc injectors any good?
homeslicej2
I dunno about the injectors, but Mazworx sells a headstud kit made with ARP material for about the same $ as the ARP headstuds. Difference is, theirs will actually fully engage into the block. The ARP ones that everyone sells are not designed specifically for the DET and they don't seat all the way. Get the MAzworx ones.
idamaster
Well I thought pretty well about this. If Im going to upgrade the HP in my car im going to do it right. Probably wont be for a while But im going to do it with all the right parts and not half a** it.
