Hijacker wrote:
I'm confused as to how the GT30 is using the same housings as the T25/T28, or are you talking about the flanges?
Looking at the math, the wheels are totally different and the frame is a GT30, which is different from the T2 based frames.
/threadjack
Either or, to the OP your T3/T04 should be fine. Sr owners have been using them for a looooong time now with no troubles. If you're worried about it, there's a great thread on the boards about making a 400 hp SR on a GT2871rs .64 a/r
Garett GT3071R-WG Turbo is based upon the same turbo as the HIGH flowing, larger framed GT3071R, but conveniently packaged into the T25/28 same style turbine housing as the popular GT28Rs/GT2871R turbos. This Garrett GT3071R-WG turbo is uniquely configured with its own turbo wheel trim, turbine A/R, and compressor housing. Unlike, the GT28RS and GT2871R, this turbo now has a much larger compressor housing to support the much higher flowing 71mm compressor wheel. Comes with T25 style inlet flange.
