Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Wed Sep 17, 2008 7:29 am
This is a pretty well covered topic.
But I'll be kind.
You need to look at your end power goals with whatever turbo you end up going with and base upgrades off that. If you're going over the stock power output, you will need to upgrade your fuel management (MAF, injectors, ECU). Also, you'll have to modify your intake piping as the DP doesn't use the stock equipment.
Look at Sport Compact Car's project car section. Dave Coleman did an article years ago that should still be hosted on the site concerning an upgrade to the DP.
