RMiller »
https://forums.nicoclub.com/rmiller-u12169.html
Tue Dec 28, 2004 5:47 pm
Hehem. I love answering this question.
For a t3/t04 you need:
-t3 flanged exhaust manifold (stock flange is different)-external wastegate-custom downpipe and wastegate pipe. This will be very difficult if you want the wastgate gas to merge back with the rest of the exhaust-oil lines-inlet and outlet pipes, silicone couplers and non-crappy clamps-flange for downpipe, flange for wastegate-gaskets
Stock injectors and increasing the boost on a big turbo, are you mad? And since you won't be using stock injectors and raising the boost, you'll either not be making any more power than you could make with a t25, or you'll need new bigger injectors, z32 maf or alternative, a boost controller, and something to make the injectors and maf work.
Consider a bolt on turbo like a t28 or 2871r, 550's, z32 maf and a rom tune. Even if you bought it new it could cost you less than what the flex coilovers would have cost you.
