Turbo tuning solutions?
qsiguy
Car: 1994 Infiniti Q45 Turbo
I haven't found anyone that's installed a turbo on their Q but I am concidering it. STS Turbo ( http://www.ststurbo.com ) has a rear mounted setup that would take the place of the rear muffler on the Q. Although they don't have a package specifically for the Q they can supply a universal package that will take care of most of the needs. My question is what's the best or recommended method of tuning to readjust the fuel mixture to compensate for the additional air. I've seen the Jim Wolf ECU mentioned. Will this allow me to make the necessary adjustments? If so, where can you get this and how much should I expect to pay? The STS basic setup will give me 5-8psi of boost. Also need to know if larger injectors may be needed. Anyone have any info on this subject? I have seen the Q motor used in other vehicles where turbos were installed, just not on the Q.
What do you all think?
qsiguy'94 Q45
Modified by qsiguy at 2:55 PM 11/15/2005
Rex
Car: None
450zxtt has a twin turbo VH45DE, but it's in a Z32 (300ZX). So, it's been done. Some one has the maps somewhere.
IIRC, the injectors are good to ~450hp, based on there max flow values, so I think you cna run the stock (in good operating condition) injectors.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
JWT boost map is ready to go.....
qsiguy
What does that mean "JWT boost map is ready to go..." I'm new to ECU tuning. Can someone explain it to me briefly? I've played with OBD2 stuff a little as a friend has software on his laptop for it but not sure what I'd need to do on the older stuff.
qsiguy
elwesso
2007 BMW M Coupe
JWT= Jim wolfe technology
They make a boost ECU for the Q.
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
I would install it with the stock ECU. It should be able to handle 5# of boost with the stock injectors and MAF (just my opinion - no experience YET).
GRADEST
Kenne Bell makes superchargers and other components. He makes a product called a boost- a- pump. This controller adjusts the voltage to the fuel pump based on a booost or vacuum reference. Increase fuel press., increase fuel volume------ its simple and it works. I like the remote turbo too. This would take care of the fuel enrichment . Any one have an idea for the spark mapping. Is there some kind of piggy back controller that would work. Also, does anyone know how well the q45 mass air meter works in a blow-thru application? I wouldnt want to relocate my air meter to the rear also!
elwesso
2007 BMW M Coupe
Yep as long as you put the MAF on the pressure side......
PoorManQ45
God damnit, this is at least the 4th time this same EXACT discussion has been had.
elwesso
2007 BMW M Coupe
I cant believe you actually said that.
PoorManQ45
I know right.
RobertsnewQ
Email me I can do it.
Easy change to the ECU.
elwesso
2007 BMW M Coupe
RobertsnewQ wrote:Email me I can do it.
heywier427
Car: 91 Q45
im interested in this setup how did you get the info from the website
qsiguy
what info are you referring to?
elwesso
2007 BMW M Coupe
Good luck at getting the tubing up into the engine bay.
qsiguy
Ya, haven't worked all that out yet, still debating spending $3K for the kit. Did just speak with a tech at Jim Wolf about the ECU. Sounds like a no brainer, just fork over the $595. MAF and injectors he agreed, should be fine as long as I don't go over 6-8 PSI. Over that he wasn't sure. He only knew of one person who put a supercharger on a Q but no turbo's. I think I need to be the Pioneer and get-er-done!
Q45CALIBER
Car: Black on Black 94 Q45
elwesso wrote:Good luck at getting the tubing up into the engine bay.
Remote Turbo may be better in that case
WDRacing
There's always a simple FMU or RRFPR. Perhaps a tad retard of the base timing by 2 degree's and you should be more then fine for fuel. Aslong as you never go more then 8-9 psi, so the fuel line/rail pressures don't get to high while you're on boost. FMU is WAY cheaper then the JWT ECU rom tune.
WD
elwesso
2007 BMW M Coupe
unless you have the extra super special NICO ecu hook up for the Q.....
Stay tuned!
qsiguy
HEY! No holdin out on us, hook us up!
elwesso
2007 BMW M Coupe
qsiguy wrote:HEY! No holdin out on us, hook us up!
Im testing the ECU right now... will post more information on its effectiveness later this week.
Rex
Car: None
elwesso wrote:Im testing the ECU right now... will post more information on its effectiveness later this week.
Weather permitting , and would the excessively cold air possibly impact the results of your butt dyno?
elwesso
2007 BMW M Coupe
We'll find out, next week its supposed to be around 45ish, where it has been as of recent.
Q45CALIBER
WDRacing wrote:There's always a simple FMU or RRFPR. Perhaps a tad retard of the base timing by 2 degree's and you should be more then fine for fuel. Aslong as you never go more then 8-9 psi, so the fuel line/rail pressures don't get to high while you're on boost. FMU is WAY cheaper then the JWT ECU rom tune.
WD
Please excuse but I am trying to keep up here what is FMU and RRFPR?
Q45CALIBER
I Got It....FMU is generally referring to a Rising Rate Fuel Pressure Regulator(RRFPR).
WDRacing
Exactly, you can change how much the fuel pressure goes up by swapping out the internal rubber chingus. If you have a 12:1 chingus and you're running pig rich, just swap in a 10:1 chingus. Easy and works well for guys running a low amount of boost.
WD
GRADEST
That wasnt very nice. That is the easy part, besides a co. called Dr. Gas in sandy utah that makes all kinds of oval nascar tubing and crazy bends and like oval to round adapters etc. Healso makes these killer x-pipes and they work good. I had one on my 5.0 they create avery unique almost high pitched note and very smooth. I congradulate turbo man . You can do it . You are turbo man. DO it Do it. DO it I wouldnt count on jim wolfs tune . You could have it tuned on a local dyno by a local tuner and come up from the safe side of power and probably be much happier. Plus then you could get a tune for 91 octane and a tune for race gas and you have recorded settings for both. Any one who puts boost in theyre car needs accurate real time o2 monitoring during tuning.
fjirousek
Car: 1992 Infiniti Q45, 1991 Plymouth Laser RS
I thought there was a thread somewhere about a twin turbo kit from Japan. Does anyone have any detailed info on that?
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
fjirousek wrote:I thought there was a thread somewhere about a twin turbo kit from Japan. Does anyone have any detailed info on that?
my friend is friends w/ the owner of HKS or one of those companies he had a TTQ back in the late 90's in Japan
