turbo trim
mean green s14
Car: driving like a retard
i have a garrett t04b turbo and is a a/r .60 with a .58 exhuast - what does this mean? is this a good turbo for my ka24de????i need feedback before i put it on please help!
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
your just joking right?
you bought a turbo and you don’t know anything about it...I don’t want to look rude, but whata hell?
do you have the manifold and all other parts?
mean green s14
yes i have everything! im looking for feedback on anyone who has this turbo or who can tell me a little about it abd its specs or performance,so no this is not a joke just a question from someone who doesnt know any better.
Checkered-Member
I’m just startled by all this…
Back to your question, the .58 is the size of your exhaust turbine…
yes that turbo will be perfect for the KA24DE.
C-Kwik
Wrong. The A/R is not the size of the turbo. It refers to the size of the nozzle. A/R actually means Area/Radius. The area of the nozzle divided by the radius. In practice, it's usually the area that changes. But theoretically, as long as the ratio is the same though, the velocity at a given flow rate stays the same.
The size of the turbo is largely dictated by the name(Garrett turbos). T04B refers to the compressor. All T04B's have the same compressor major diameter. The Minor diameter is what changes the trim. Measure the minor diamter and you'll be able to determine the size against Garrett's/Turbonetic's catalog. The turbine is also measured in the same fashion, the specific size of the turbine is usually left out. And Garrett also does not necessarily use the same major diameter within the same turbine family as they for the most part do with the compressors. If you have a T4 turbine housing though, you likely have a 2.922" major diameter.
As far as this being the perfect turbo, it depends. Depends a lot in fact on how much boost you will be running. The T04B will be good enough to handle a broad range, but it may start to suffer in higher boost levels. Upwards of 10 psi, I'd be looking into the T04E compressors.
Checkered, before you start being "startled" by others, please take a step back and actually learn what you are talking about before posting it up here. If you are wrong, you are wrong. I have no problem with that. But if you slam a guy for not knowing anything about a turbo and then post poor information yourself, you're being a hypocrite. Perhaps if you just answered the question, you wouldn't look so bad.
trpower7
Word
mean green s14
im going to run 7psi on a ka24de with stock internals and was just wondering how this turbo will do at 7psi since it is a larger turbo than most people use on a ka24de egine ,most ive seen use the t3/t4 hybrid instead of a full t04 turbo.
TopStreet240
Car: Cars! movies, books,
that might be a little big and you might have a hard time keeping your boost down that low. I have a SC-54 which is a 60 trim turbo from PTE and right now im running on stock external wastegate boost setting. (6psi) but at the top of the gear under load i get boost creep up to 8psi, its not really a bad thing, but you might want a smaller turbo if 7psi is all your going for. I would also check out the map of the turbo, if your only going to be running 7psi you may be way out of the efficency range of that thing. Its not the worst, but a different turbo could make your car spool faster making it quicker for what you are looking for.
TrunkMonkey
Car: 2000 Lincoln Navigator
i just took a peek at the compressor map for your turbo mean green, and it's too big. if that's all you have to work with, then stick with low boost and you'll be ok. i hope lag isn't a problem for you, cause you will definitely have it.
the best way to pick a turbocharger is just as c-kwik mentioned. determine how much boost you want to run first, and then go shopping.
-demetrius
mean green s14
could you post the compresser map for me id love to see it!
C-Kwik
There are 3 T04B compressors. Look through the compressor inlet. Measure the diameter of the blades you can see. Once you post this, we can figure out which T04B you have and then point you to the right map.
TopStreet240
also you could check on my website, im not sure but we might have your map. http://www.topstreetperformance.com
TopStreet240
oh, the maps are under tech info
TrunkMonkey
umm. ignore my last post. i just realized something. i went through and plotted all the to4b maps that i have...
with numbers for my saturn :hiding: .
-demetrius
mean green s14
the turbo says m-24 b.o
cory2081
Car: '07 Nissan 350Z
you should have mail mean green....waiting on a reply.....
mean green s14
i sent it friday man! i had to scribble out all the bar codes and numbers from the first time it shipped.i dont know if i told you that or not but thats what happened.i would thing you should get it on turkey day if they deliver mail?
cory2081
just checking, thanks man!!
