dude read closer240SXplan wrote:yes, I got this turbo from my cuz.. and he was not too happy with the lag.. but it does pull hard when it kicks in.. it looks good over all and it is twice as big as my stock turbo.. no one have answer my questions yet?
power? lag? spool time? on my rb25det
Those numbers really don't make a lot of since... What is a Mayor? If it's suppose to be the Inducer side then the compressor numbers have something wrong since the Exducer should be bigger than the inducer...240SXplan wrote:i got this turbo sitting in my garage.. and i like to know what kind of power it will make for my RB25DET..?? from SSAutochrome..com..
1. power? 2.lag? 3. spool time?
spec on the turbo.T04 " O " T3/T4 .70 A/R TURBINE HOUSING Turbine Wheel:Exducer: 2.54"Mayor : 2.89" Compressor Wheel:Exducer: 2.23"Mayor : 3.31" Turbine Housing:70 " DIVIDED TANG FLANGE
looking for around 350 to 400 HP..
Modified by 240SXplan at 2:02 AM 10/25/2005
If the exducer is the compressed air outlet and the mayor is the air inlet than those measurements can be correct can't they? I have two turbos in my garage that have a larger air inlet than outlet on the compressor side.rbsileighty wrote:Those numbers really don't make a lot of since... What is a Mayor? If it's suppose to be the Inducer side then the compressor numbers have something wrong since the Exducer should be bigger than the inducer...
I'd pass on this turbo if I was you...
Modified by rbsileighty at 6:07 PM 10/26/2005
