turbo timer
civics91
Car: cars,cars,cars
i have a turbo timer and i need to know what wires to splice in to can some one tell me what ones thanksps i have a sr if u need to know that
lok
See if you can get the harness, since they are only 10-15 dollars, and make it much easier.
Also what brand of TT do you have?
doritaka
i recomend to use a timer harness. why would you want to splice the original harness? if you have 4 wires on the plug , the timer harness is around $24 here.
runyun
to make it work.. only 3 wires under the steering column.acc, ground, ignition. Its all in the instructions
(unless you bought yours used)
then, there is the ebrake wire and speed sensor. ck your manufacturers website.. it might have directions, or use any instructions. They all work the same
civics91
Car: cars,cars,cars
it a apexi and i got u used from a buddy for 30 doller and he cut the wires off so there is no clip in the end
runyun
Ya, you dont need the clip - unless you have a harness for your car, you have to cut it off.
There should be 3 big wires (acc, ground, ignition) and two smaller ones (speed sensor and ebrake) coming out from the turbo timer.
Tell me what color your wires are (from the turbo timer)
