car is a 89 s13 with sr20 redtop
Yes I have search many post on multiple forums and tries all ways. My issue im having is im splicing a greddy turbo timer into my s13. From what i see i have 5 wires on my ignition switch
White/red strip
Blue
Black/green strip
Black/white strip
Black/yellow strip
I know the white/red is 12v constant.
idk if my ignition has two ACC or not. The timer has a good ground. Problem is idk what the wires from my timer go onto my ignition harness. The timer has a red which goes to 12v constant, a green wire, a blue wire and a black which goes to ground. When i have the wires on the timer hooked up by what other forums say the timer turns on and displays OFF and shuts off when i turn the key to the first ACC. any info would help
