adidas2go »
https://forums.nicoclub.com/adidas2go-u78832.html
Sun May 04, 2008 3:21 pm
Anyone ever installed or heard of anyone installing a turbo timer on their push button start?
I took readings at all the wires that connect to the ignition button, but none of them seem to actually control the start/stop, they just send the signal to another module that does it. This is what I came up with at the ignition button.Voltage readings are in the order of, OFF, ACC, ON, and START for each wire. Brown- 12V,12V,12V,13V; Red- 12V,.5V,.5V,.5V; Yellow/Blue- 12V, .1V,.5V,.5V; Turquoise- 12V,12V,0V,0V; Green/Yellow- 12V,12V,12V,12V; Black - GROUND; Orange/White-.1V,.1V,.1V,.1V; White- .6V,.6V,.6V,.6V
They all have constant power in the OFF position, except the last 2 which I believe are used for the light bulbs interior of the switch. Not at all like a normal key switches wires. If anyone knows anything, let me know. Thanks
