Katapl »
https://forums.nicoclub.com/katapl-u46973.html
Sat Dec 30, 2006 10:15 pm
I installed a HKS Type-1 TT. I routed everything in as it said. I hooked the RPM wire into the right place in the ECU (according to PLX) and it read RPM fine on the unit. Then I hooked the speed line into what was apparently the Vehicle Speed Sensor... #32, which was a yellow with green stripe wire, I believe, and with gray dots. I reinstalled the cluster, and the unit wasn't reading speed, nor was the cluster. I removed everything and taped the wire back up. It still didn't read.
I'm afraid I may have bumped some circuits on the back of the cluster and damaged the speedo, or something to do with taping into the speed sensor wire on the ECU. It does appear to have 2 white scratches pretty close to the speedo on the backside of the cluster. FYI, it's a USDM turbo timer and a JDM gauge cluster.
Any ideas?
