Turbo timer install (s13 questions) w/ pictures
NewYorkCoupe
Car: 89 rb 240sx coupe, 99 mazda miata
Alright so I came into possesion of an Apexi turbo timer. I didn't get instructions and the factory plastic connector is cut off.
This is where I am right now, I know the three main wires (red, green, and blue) have to be hard-wired into the ignition wires. I know that the black wire has to go to the e-brake wire.
Here is the cut wires on the turbo timer.
And the wiring going to the ignition, I removed the plastic connector to easier see the wire colors.
If someone can help on which wires on the timer go to which wires on the ignition Id greatly appreciate it.
The info on turbo timer hard-wiring is sketchy at best in the search center.
Id be forever in your debt guys
project_240le
Car: 1991 nissan 240sx le
red wire: (+12v constant)- connect to white ign. wire with red stripeblue wire: connect this to the white ignition wire with a blue stripegreen wire: connect this to the black ign. wire with a white stripe
gray wire goes to the e brake.black wire goes to ground.white wire goes to the o2 sensor wire on the ecu.
hope this helps, thats how i wired it up on my 1990 s13
NewYorkCoupe
Worked like a charm. Thanks again.
