Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Sat Apr 27, 2013 7:18 am
It's probably the timer. Make sure your PNP harness is supplying 12v to the black/red wire. That's the ignition switch's 'on' circuit.
Also, if this is on a swapped car, it's possible the timer can't cope with the voltage drop of the typical hacks for running the ignition system. Most swaps tap the ignition system from the black red at the Chassis -> EFI harness plugs by the battery. JDM factory setup puts the ignition system on a relay to take the load off the ignition switch's 'on' circuit. The ignition switch is stout enough to handle the current requirements, but it's possible the timer isn't as stout.
More than likely though, something just isn't plugged in properly.
