Turbo timer help.
drEameRvaJ
Car: 1997 Nissan 240SX SE
Well, I have a Greddy turbo timer that I installed on my non-turbo KA. I bought the harness to make everything easier for installation. I plugged up both the wires, ground, and also the e-brake. When I turn my car on, the turbo timer starts counting down and it shuts off, but if I turn my car on and let the e-brake down than it stops it from counting down BUT than when I turn my car off, the turbo timer doesn't shut the car down. HELP? I don't know what's wrong.
S13FX
Car: '69 l20b Dimeski :)
Unhook the E-Brake wire.
coolbone28
if you bought your wire harness from phase2 then you have to switch them around. I had to do some electrical trouble shooting and figure out which wires from the ignition were the right ones. if you really want me to I can go look at which wires i have hooked up.
drEameRvaJ
When I didn't have the e-brake hook up, the whole thing wouldn't work. I'm not sure where this harness came from, I bought this item from a fellow NICO member a long while back. Thanks for the replies. ANYONE, HELP!?
Chezedik
Car: 1991 Nissan 240sx
Run it under a bolt, see if that fixes your problem.
drEameRvaJ
Thanks to the people who responded.
But I solved the problem.
It was just the setting under the timing and I had to switch the little switch on the back. It runs perfect now.
THANKS AGAIN NICO MEMBERS.
WDRacing
Glad everything worked out for ya!!! Nico rocks!
