You should do it....make sure it's a low compression motor...so you can boost it...wild_maxx wrote:I just bought a 95' nissan 4x4 hardbody pickup with the ka24E motor.... i already had 2 kaE-t in my 240.... so of course i was thinkin of turboing this truck before i even bought it
I was talking with a tech about doing the turbo setup and he pretty much said no point in doing it because of the heavy weight of the truck and a turbo would put to much strain on the motor if haulin stuff, off roading ect.....
He reccomended i just put in a bit higher comp. pistons and a better cam for about 30 hp or so and better low end torque....
question is... i do wan't to do some off roading and i will be hauling stuff with this truck so would a turbo be a bad idea? i just wan't a good 200 hp setup, small t3... bigger injectors (nothing overkill) maybe a FMIC i already have a safcII and wideband to tune, and a turbo manifold & DP. make an exuast system...
Or just rebuild it with 10:1 pistons and an oem rebuild and call it good? i want this motor to last a while....
because without it, it wouldnt go anywhere, lolIamjohnhayes wrote:why is almost every production diesel truck turbo ???
That is so true. I have grenaded many turbos and engines.....Chezedik wrote:Definately, this may seem counterintuitive, but keep in mind as load increases timing will be advanced but the engine will also come onto boost. And KA-BOOOM KA.
