encasemyheart »
https://forums.nicoclub.com/encasemyheart-u1676.html
Thu Jul 10, 2003 1:08 pm
There is no pressure check or anything, you can spin the compressor wheel and see if it is hard to spin or if it wobbles.
Regardless if it is from a junkyark I would rebuild before letting it touch my car.
Unfortunately you cannot rebuild it, well, you can up to a point, but it has to be balanced. Unless you can spin the wheel at 150,000rpm and balance it by hand you're out of luck. Sorry.
I believe turbonetics in quoted me $200 when I was thinking about using a junkyard turbo.
