boost_boy »
https://forums.nicoclub.com/boost-boy-u2853.html
Mon Aug 09, 2004 8:02 am
Hey red,
I wouldn't worry about trying to snatch apart the T25 to verify this! I do know a piece like the one you showed us can not possibly come from the internals of this motor, so please trust me on this one. I sold you the motor and I will guarantee the motor is not the culprit. The turbo is one that I can't be so sure about because turbos are under extreme operating duties and could crap at any given time. There's usually no warranty when you start cracking the motor open, but I can only assure you that your concerns are valid yet too concerned with the wrong thing. If you value my credibility, do as I ask. You are chasing a ghost that you'll never find. Freakish as it is, it is not any part from the physical CA18DET. I just did a head, headgasket, rod bolts, timing belt, rod bearings, etc and it only confirms what I already knew that there is nothing remotely similar able to come off the bottom or top end of this motor. So put on your new turbo and call it a day.
Dee
